19s or 20s??
Lemon Grove
So I cant decide if I should go with 19s or 20s? I would love to fill in the cap and I'm not planning on lowering my car. Would 20s be an overkill? I haven't seen a lot of 19s on a stinger. People usually go with 20s. Theres a price difference of only a couple of hundred bucks. I'm planning on running 40 series tires if I go 19s. The roads around here arent that great.
Sioux City
If you're not planning on lowering it I'd stick with 19". 20" are going to look too thin.
SeoulStinger
Walnut Creek
2015 Audi A6
It depends on the wheels, what did you have in mind?
M
Lemon Grove
Digging these wheels.. stance_wheels_sf07_gunmetal_brushed_tinted_face_rims_audiocityusa_0.jpg
But there are so many options. I want to make sure that itll look&fit right. I dont want to regret it down the line.
You have great tastes, those Stance wheels are beatiful. Personally I'd go with 20" wheels.
This Stinger is riding on 20" wheels and stock suspension. I think it looks just fine.
M
Lemon Grove
Wow that does looks good. Will I have rubbing issue with it being so close to the wheel well?
No because you would just get thinner tires so your overall diameter would be the same. [MENTION=495]BestWheelDeals[/MENTION] and [MENTION=850]GetYourWheels[/MENTION] sells Stance wheels and can get you the correct size.
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
Overland Cayenne Diesel
Digging these wheels.. View attachment 1583
20X9 and 20X10.5 is a good fit for the Kia Stinger.
If you're really OCD and want the same rolling diameter, I would stick with the 19X8.5 and 19X9.5.
M
Lemon Grove
Well im rolling the 18s stocker. I've never drivin a car with 19s or even 20s so I dont know how the ride quality would be.
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
It won't be stupid harsh or anything. You loose a little but it won't be drastic enough to hurt you or make things really uncomfortable. I've driven everything from 19" and 20" with 40/35 profile staggered and 35/30 profile staggered. Most of my ride quality change came from suspension changes.
Just know that it won't be like getting some new coilovers in some weird super high spring rate.
Paradise
I'm also shopping for another set of wheels (doing summer/winter setup here in PA). 20" looks too big for me and thinner sidewalls than I like. I'll be sticking with 18-19". Lots of wheels look good on this car! I've got 5-6 I'm deliberating about. Will share as decision narrows.
M
Lemon Grove
I believe you said "staggered" set up is ok as long at the tire width stay the same. Well I'm thinking 20x9 up front and 20x10.5 in the rear, would that be ok with awd?
GetYourWheels
Vendor
Santa Fe Springs
Santa Fe Springs
staggered setup is ok as long as the tire overall rolling diameter is the same.
235/35/20 - 275/30/20 for those that want a bit of stretch on the 9/10.5
245/35/20 - 285/30/20 for those looking more of a meaty tire look without rubbing.
also will need to consider what offsets to run.
M
Lemon Grove
Thread Starter #14
Yeah I'm debating on that too but 20s do look real good... 2018_kia_stinger_gt_niche_gamma_staggard_front_20x9_rear_20x10_5_wheels_nitto_555_g2_245x30_r_20.jpg
I love the stock 19?s on mine. The only thing I would change would be the width on the front tires. Looks a little too ricey with the sidewalls going inward
M
Lemon Grove
Thread Starter #17
So I'm going from 18s to let say 20s, will I notice any difference in weight? Drivability?
Louisville
KY
2018 Kia Stinger Premium
Without a doubt go with the 20"[biggrin]
Have you decided lol? Want to see those bad boys on your Stinger.
