Stagger or square
Edomme
Albuquerque
NM
2022 G90 Ultimate AWD
Looking to replace my tires - want the best ride quiet and comfort - can I change the stagger to square - currently on my G90 (2022) I have 245 x 19 fronts with 275 x 19 rears - can I forget the stagger and go with 245’s all the way around -……. and could I change the 19 inch wheels to 18, to get more rubber between car and road?
Quietpro
Crofton
MD
G70
I'm not qualified to answer this but, from my experience with other vehicles and groups, this should be doable. Bottom line, I'd confirm the potential issues below are addressed before making the changes.
What you'll need to confirm is whether the drivetrain will have issues due to the different wheel circumference (ABS, traction control, stability control). However, even if there is an issue, it should be possible to update the system (via tune) to adjust for the wheel and tire size changes.
