Genesis G70 Wheel Size, Bolt Pattern, Offset & Tire Information
A
Admin1
Guest
Stock Genesis G70 Wheel Information:
8.0J×18
8.0J×18
8.0J×19
8.5Jx19
Genesis G70 Hub Centric Ring:
67.1mm Hub Centric Diameter
Genesis G70 Wheel Weight:
19" - 34lbs
Standard Genesis G70 Wheel Offset:
Depending on the wheel, you can go with an offset from 34mm to 42mm.
Genesis G70 Tire Sizes:
Michelin Pilot Sport 4 225/40/R19 & 255/35/ZR19 (Included)
Continental ContiSportContact 225/40/ZR19
Bridgestone Potenza RE97AS-02 225/45/R18 & 225/50/R17
18" Tires
225/45 R18 (Recommended)
19" Tires
225/40 R19 Front (Recommended)
255/35 R19 Rear (Recommended)
Genesis G70 Bolt/Lug Pattern:
5x114.3 or 5x4.5
Genesis G70 Tire Pressure Sensors TPMS:
Ford Part# 52933 J5000
tandyman
2002 Buick Park Avenue
Nice Photos!. I am new here but I do research for the Hyundai/Genesis cars. I see the "Sport model" has 19" 5 spoke staggered wheels but no photo. I also see no availability in the US so far for 2 different 18" wheels. Can you confirm what I am seeing here?
Are you referring to these wheels?
