New Shoes
It’s seems to be a lot longer than what a lot of others are getting out of the rears. My front tires are only at half life
Are all those miles @CKeeler from normal driving or is there some burnouts amongst your driving. :rolleyes::D I have the PS4, just what to see how long they are going to last. I don't drive a lot so I figure the tires will dry rot before I wear them out.
That is certainly a lot more than what other owners are reporting. I'm on my third set (including the oem ones). OEM set lasted me a littler over 13k miles, the second 12.5k miles and now this one is already at 2k miles, I'm running lower tire pressures to get a more even wear on the tire.
From day one I ran the tires at 40psi cold. After seeing how they wore down I’m going to start running at the OEM psi. They wore down just a bit more in the center so bringing it down a couple psi I think they should wear evenly for me
2018 Kia Stinger Limited
Have you considered running the "4s" version for nearly double the life instead of the "4"?
I have, but the times I've had to shop for a new set the 4 have been on special, so I go with those :)
I'm probably changing my wheels when time comes to replace the set I'm currently using.
